Aleks
STM32CubeProgrammer 2.9.0 download to flash with problems. And 2.10 too.
  • March 12, 2022
  • 3 replies
  • 1261 views
Hi!
  1. I download firmware to internal flash STM32H725 over STLink V2 with STM32Cube Programmer 2.9.0. Very often after downloading firmware to chip, Cube Programmer report to log window "File download complete", but firmware is not updated or chip even don't to start up after hardware reset. But after second trying to download firmware the chip startup proper.
  2. Also very often Cube Programmer lost connection with chip. After connection it himself download firmware to chip exactly number of I pressing to download button times, while trying to download firmware. I think one successful download is enough.
Thank you!.
Aleks
AleksAuthor
17:08:33 : STM32CubeProgrammer API v2.10.0 | Windows-64Bits
 17:08:36 : Read File: D:\temp\firmware.bin
 17:08:36 : Number of segments: 1
 17:08:36 : segment[0]: address= 0x0, size= 0x5DA88
 17:08:39 : ST-LINK SN : 50FF6F067871515131090367
 17:08:39 : ST-LINK FW : V2J39S7
 17:08:39 : Board : --
 17:08:39 : Voltage : 3.23V
 17:08:39 : SWD freq : 4000 KHz
 17:08:39 : Connect mode: Normal
 17:08:39 : Reset mode : Software reset
 17:08:39 : Device ID : 0x483
 17:08:39 : Revision ID : Rev Z
 17:08:41 : Error: ST-LINK error (DEV_TARGET_RESET_ERR)
 17:08:43 : ST-LINK SN : 50FF6F067871515131090367
 17:08:43 : ST-LINK FW : V2J39S7
 17:08:43 : Board : --
 17:08:43 : Voltage : 3.23V
 17:08:45 : SWD freq : 4000 KHz
 17:08:45 : Connect mode: Normal
 17:08:45 : Reset mode : Software reset
 17:08:45 : Device ID : 0x483
 17:08:45 : Revision ID : Rev Z
 17:08:45 : ST-LINK SN : 50FF6F067871515131090367
 17:08:45 : ST-LINK FW : V2J39S7
 17:08:45 : Board : --
 17:08:45 : Voltage : 3.23V
 17:08:47 : Error: ST-LINK error (DEV_TARGET_RESET_ERR)
 17:08:55 : ST-LINK SN : 50FF6F067871515131090367
 17:08:55 : ST-LINK FW : V2J39S7
 17:08:55 : Board : --
 17:08:55 : Voltage : 3.23V
 17:08:57 : SWD freq : 4000 KHz
 17:08:57 : Connect mode: Normal
 17:08:57 : Reset mode : Software reset
 17:08:57 : Device ID : 0x483
 17:08:57 : Revision ID : Rev Z
 17:08:57 : ST-LINK SN : 50FF6F067871515131090367
 17:08:57 : ST-LINK FW : V2J39S7
 17:08:57 : Board : --
 17:08:57 : Voltage : 3.24V
 17:08:59 : Error: ST-LINK error (DEV_TARGET_RESET_ERR)
 17:09:07 : ST-LINK SN : 50FF6F067871515131090367
 17:09:07 : ST-LINK FW : V2J39S7
 17:09:07 : Board : --
 17:09:07 : Voltage : 3.23V
 17:09:07 : SWD freq : 4000 KHz
 17:09:07 : Connect mode: Normal
 17:09:07 : Reset mode : Software reset
 17:09:07 : Device ID : 0x483
 17:09:07 : Revision ID : Rev Z
 17:09:08 : Error: ST-LINK error (DEV_TARGET_NOT_HALTED)
 17:09:12 : ST-LINK SN : 50FF6F067871515131090367
 17:09:12 : ST-LINK FW : V2J39S7
 17:09:12 : Board : --
 17:09:12 : Voltage : 3.24V
 17:09:13 : SWD freq : 4000 KHz
 17:09:13 : Connect mode: Normal
 17:09:13 : Reset mode : Software reset
 17:09:13 : Device ID : 0x483
 17:09:13 : Revision ID : Rev Z
 17:09:13 : ST-LINK SN : 50FF6F067871515131090367
 17:09:13 : ST-LINK FW : V2J39S7
 17:09:13 : Board : --
 17:09:13 : Voltage : 3.24V
 17:09:15 : Error: ST-LINK error (DEV_TARGET_RESET_ERR)
 17:09:20 : ST-LINK SN : 50FF6F067871515131090367
 17:09:20 : ST-LINK FW : V2J39S7
 17:09:20 : Board : --
 17:09:20 : Voltage : 3.23V
 17:09:20 : SWD freq : 4000 KHz
 17:09:20 : Connect mode: Hot Plug
 17:09:20 : Reset mode : Software reset
 17:09:20 : Device ID : 0x483
 17:09:20 : Revision ID : Rev Z
 17:09:20 : Debug in Low Power mode is not supported for this device.
 17:09:21 : UPLOADING OPTION BYTES DATA ...
 17:09:21 : Bank : 0x00
 17:09:21 : Address : 0x5200201c
 17:09:21 : Size : 92 Bytes
 17:09:21 : Memory Programming ...
 17:09:21 : Opening and parsing file: firmware.bin
 17:09:21 : File : firmware.bin
 17:09:21 : Size : 374.63 KB
 17:09:21 : Address : 0x08000000
 17:09:21 : Erasing memory corresponding to segment 0:
 17:09:21 : Error: Unable to read device id from ROM table
 17:09:21 : Erasing internal memory sectors [0 2]
 17:09:21 : Download in Progress:
 17:09:24 : File download complete
 17:09:24 : Time elapsed during download operation: 00:00:03.529
Aleks
AleksAuthor
 17:09:24 : Memory Programming ...
 17:09:24 : Opening and parsing file: firmware.bin
 17:09:24 : File : firmware.bin
 17:09:24 : Size : 374.63 KB
 17:09:24 : Address : 0x08000000
 17:09:24 : Erasing memory corresponding to segment 0:
 17:09:24 : Erasing internal memory sectors [0 2]
 17:09:27 : Download in Progress:
 17:09:31 : File download complete
 17:09:31 : Time elapsed during download operation: 00:00:06.465
 17:09:31 : Memory Programming ...
 17:09:31 : Opening and parsing file: firmware.bin
 17:09:31 : File : firmware.bin
 17:09:31 : Size : 374.63 KB
 17:09:31 : Address : 0x08000000
 17:09:31 : Erasing memory corresponding to segment 0:
 17:09:31 : Erasing internal memory sectors [0 2]
 17:09:33 : Download in Progress:
 17:09:37 : File download complete
 17:09:37 : Time elapsed during download operation: 00:00:06.474
 17:09:37 : Memory Programming ...
 17:09:37 : Opening and parsing file: firmware.bin
 17:09:37 : File : firmware.bin
 17:09:37 : Size : 374.63 KB
 17:09:37 : Address : 0x08000000
 17:09:37 : Erasing memory corresponding to segment 0:
 17:09:37 : Erasing internal memory sectors [0 2]
 17:09:57 : Download in Progress:
 17:09:57 : File download complete
 17:09:57 : Time elapsed during download operation: 00:00:06.470
 17:09:57 : Memory Programming ...
 17:09:57 : Opening and parsing file: firmware.bin
 17:09:57 : File : firmware.bin
 17:09:57 : Size : 374.63 KB
 17:09:57 : Address : 0x08000000
 17:09:57 : Erasing memory corresponding to segment 0:
 17:09:57 : Erasing internal memory sectors [0 2]
 17:09:57 : Time elapsed during download operation: 00:00:06.479
 17:09:57 : Time elapsed during download operation: 00:00:06.499
 17:09:57 : UPLOADING ...
 17:09:57 : Size : 1024 Bytes
 17:09:57 : Address : 0x8000000
 17:09:57 : Read progress:
 17:09:57 : Data read successfully
 17:09:57 : Time elapsed during the read operation is: 00:00:00.006
 17:09:57 : Disconnected from device.
 17:18:47 : ST-LINK SN : 50FF6F067871515131090367
 17:18:47 : ST-LINK FW : V2J39S7
 17:18:47 : Board : --
 17:18:47 : Voltage : 3.23V
 17:18:47 : SWD freq : 4000 KHz
 17:18:47 : Connect mode: Hot Plug
 17:18:47 : Reset mode : Software reset
 17:18:47 : Error: Unable to read device id from ROM table
 17:18:47 : Error: Cannot identify the device
 17:18:51 : ST-LINK SN : 50FF6F067871515131090367
 17:18:51 : ST-LINK FW : V2J39S7
 17:18:51 : Board : --
 17:18:51 : Voltage : 3.24V
 17:18:51 : SWD freq : 4000 KHz
 17:18:51 : Connect mode: Hot Plug
 17:18:51 : Reset mode : Software reset
 17:18:51 : Device ID : 0x483
 17:18:51 : Revision ID : --
 17:18:51 : Voltage : 3.23V
 17:18:51 : Debug in Low Power mode is not supported for this device.
 17:18:51 : UPLOADING OPTION BYTES DATA ...
 17:18:51 : Bank : 0x00
 17:18:51 : Address : 0x5200201c
 17:18:51 : Size : 92 Bytes
 17:18:51 : Error: Uploading Option Bytes bank: 0 failed
 17:18:51 : Error: Initializing the Option Bytes failed
 17:18:51 : Disconnected from device.
 17:18:54 : ST-LINK SN : 50FF6F067871515131090367
 17:18:54 : ST-LINK FW : V2J39S7
 17:18:54 : Board : --
 17:18:54 : Voltage : 3.24V
 17:18:54 : SWD freq : 4000 KHz
 17:18:54 : Connect mode: Hot Plug
 17:18:54 : Reset mode : Software reset
 17:18:54 : Device ID : 0x483
 17:18:54 : Revision ID : --
 17:18:55 : ST-LINK SN : 50FF6F067871515131090367
 17:18:55 : ST-LINK FW : V2J39S7
 17:18:55 : Board : --
 17:18:55 : Voltage : 3.23V
 17:18:55 : SWD freq : 4000 KHz
 17:18:55 : Connect mode: Hot Plug
 17:18:55 : Reset mode : Software reset
 17:18:55 : Device ID : 0x483
 17:18:55 : Revision ID : --
 17:18:55 : Debug in Low Power mode is not supported for this device.
 17:18:55 : UPLOADING OPTION BYTES DATA ...
 17:18:55 : Bank : 0x00
 17:18:55 : Address : 0x5200201c
 17:18:55 : Size : 92 Bytes
 17:18:55 : Error: Uploading Option Bytes bank: 0 failed
 17:18:55 : Error: Initializing the Option Bytes failed
 17:18:55 : Disconnected from device.
 17:18:59 : ST-LINK SN : 50FF6F067871515131090367
 17:18:59 : ST-LINK FW : V2J39S7
 17:18:59 : Board : --
 17:18:59 : Voltage : 3.23V
 17:18:59 : Error: ST-LINK error (DEV_TARGET_NOT_HALTED)
 17:19:01 : ST-LINK SN : 50FF6F067871515131090367
 17:19:01 : ST-LINK FW : V2J39S7
 17:19:01 : Board : --
 17:19:01 : Voltage : 3.24V
 17:19:03 : SWD freq : 4000 KHz
 17:19:03 : Connect mode: Normal
 17:19:03 : Reset mode : Software reset
 17:19:03 : Device ID : 0x483
 17:19:03 : Revision ID : Rev Z
 17:19:03 : ST-LINK SN : 50FF6F067871515131090367
 17:19:03 : ST-LINK FW : V2J39S7
 17:19:03 : Board : --
 17:19:03 : Voltage : 3.23V
 17:19:03 : Error: ST-LINK error (DEV_TARGET_NOT_HALTED)
 17:19:07 : ST-LINK SN : 50FF6F067871515131090367
 17:19:07 : ST-LINK FW : V2J39S7
 17:19:07 : Board : --
 17:19:07 : Voltage : 3.24V
 17:19:10 : SWD freq : 4000 KHz
 17:19:10 : Connect mode: Normal
 17:19:10 : Reset mode : Software reset
 17:19:10 : Device ID : 0x483
 17:19:10 : Revision ID : Rev Z
 17:19:10 : ST-LINK SN : 50FF6F067871515131090367
 17:19:10 : ST-LINK FW : V2J39S7
 17:19:10 : Board : --
 17:19:10 : Voltage : 3.23V
 17:19:10 : Debug in Low Power mode is not supported for this device.
 17:19:10 : UPLOADING OPTION BYTES DATA ...
 17:19:10 : Bank : 0x00
 17:19:10 : Address : 0x5200201c
 17:19:10 : Size : 92 Bytes
 17:19:10 : Memory Programming ...
 17:19:10 : Opening and parsing file: firmware.bin
 17:19:10 : File : firmware.bin
 17:19:10 : Size : 374.63 KB
 17:19:10 : Address : 0x08000000
 17:19:10 : Erasing memory corresponding to segment 0:
 17:19:10 : Erasing internal memory sectors [0 2]
 17:19:13 : Download in Progress:
 17:19:16 : File download complete
 17:19:16 : Time elapsed during download operation: 00:00:06.327
 17:19:16 : Memory Programming ...
 17:19:16 : Opening and parsing file: firmware.bin
 17:19:16 : File : firmware.bin
 17:19:16 : Size : 374.63 KB
 17:19:16 : Address : 0x08000000
 17:19:16 : Erasing memory corresponding to segment 0:
 17:19:16 : Erasing internal memory sectors [0 2]
 17:19:19 : Download in Progress:
 17:19:23 : File download complete
 17:19:23 : Time elapsed during download operation: 00:00:06.358
 17:19:23 : Memory Programming ...
 17:19:23 : Opening and parsing file: firmware.bin
 17:19:23 : File : firmware.bin
 17:19:23 : Size : 374.63 KB
 17:19:23 : Address : 0x08000000
 17:19:23 : Erasing memory corresponding to segment 0:
 17:19:23 : Erasing internal memory sectors [0 2]
 17:19:25 : Download in Progress:
 17:19:29 : File download complete
 17:19:29 : Time elapsed during download operation: 00:00:06.393
 17:19:29 : Memory Programming ...
 17:19:29 : Opening and parsing file: firmware.bin
 17:19:29 : File : firmware.bin
 17:19:29 : Size : 374.63 KB
 17:19:29 : Address : 0x08000000
 17:19:29 : Erasing memory corresponding to segment 0:
 17:19:29 : Erasing internal memory sectors [0 2]
 17:19:32 : Download in Progress:
 17:19:35 : File download complete
 17:19:35 : Time elapsed during download operation: 00:00:06.361
 17:19:35 : Memory Programming ...
 17:19:35 : Opening and parsing file: firmware.bin
 17:19:36 : File : firmware.bin
 17:19:36 : Size : 374.63 KB
 17:19:36 : Address : 0x08000000
 17:19:36 : Erasing memory corresponding to segment 0:
 17:19:36 : Erasing internal memory sectors [0 2]
 17:19:38 : Download in Progress:
 17:19:42 : File download complete
 17:19:42 : Time elapsed during download operation: 00:00:06.397
 17:19:42 : UPLOADING ...
 17:19:42 : Size : 1024 Bytes
 17:19:42 : Address : 0x8000000
 17:19:42 : Read progress:
 17:19:42 : Data read successfully
 17:19:42 : Time elapsed during the read operation is: 00:00:00.007
Aleks
AleksAuthor
It is typical message log.
