MMazz.11
STLINK-V3SET not found by texane st-util (under debian 9)
I just bought a stlinkv-3set programmer / debugger.
I currently use Eclipse IDE together with texane / st-link and openocd.
I've always worked with the discovery boards (F051 and F746G) without any problems. They use the stlinkV2 or V2.1 protocol and the st-link utility works correctly.
When I plugged my first new programmer, STLINK-V3SET, the st-link utility still refuse to recognize it.
Launching the st-info utility simply I got the following:
Found 0 stlink programmers.
I've already put the appropriate file in /etc/udev/rules.d (filename: 49-stlinkv3.rules).
Issuing the lsusb -v command I get the following:
mmazza@linux9:~/ARMtoolchains/stlink-master/build/Release$ lsusb -v
Bus 005 Device 007: ID 0483:374f STMicroelectronics
Device Descriptor:
 bLength               18
 bDescriptorType        1
 bcdUSB              2.00
 bDeviceClass         239 Miscellaneous Device
 bDeviceSubClass        2 ?
 bDeviceProtocol        1 Interface Association
 bMaxPacketSize0       64
 idVendor          0x0483 STMicroelectronics
 idProduct         0x374f
 bcdDevice           1.00
 iManufacturer          1 STMicroelectronics
 iProduct               2 ST-LINK/V3
 iSerial                3 005200363137510239383538
 bNumConfigurations     1
<more>
Any ideas.
I'm really stuck.
Thanks in advance,
Max
July 27, 2019
Find one of the developers, send then a pod and PayPal them some cash?​
Uwe Bonnes
Chief
July 27, 2019
For a programmer, have a look at https://github.com/UweBonnes/pystlink/tree/features. It know the V3.
MMazz.11
MMazz.11Author
@Uwe Bonnes​ Thank you! I will try it as soon as possible.
Max
bjorn2
Yip, try EBlink
https://github.com/EmBitz/EBlink
But for your STlink V1 keep texane.
