IMate.1
STLINK-V3MODS integration
The STLINK-V3MODS is a fantastic idea. The more engineering time I spend on the bootloader, the less time I have designing the product itself. Somebody at ST deserves a raise for the STLINK-V3MODS idea. This thing is a lifesaver! Let me know who you are, and I'll send you a case of wine! :wine_glass:
But...no stock and no forecast as to when the STLINK-V3MODS comes on the market. 1122 on order according to Mouser but no date given. You can't run a business on those terms.
Is the STLINK-V3MODS schematic available? If not, can it be made available? If so, how do I load the firmware into the blank STLINK-V3MODS micro? Can I order the micro with the STLINK-V3MODS firmware pre-installed?
Peter BENSCH
Peter BENSCHBest answer
No, the schematics and design documents are not available because the STLINK-V3MODS is also a debug tool that is not open source or open hardware. Also, the STM32 is not available pre-programmed, in fact the only option is to order the STLINK-V3MODS from your preferred supplier.
Unfortunately, the entire global economy is currently suffering from an extreme increase in demand, so waiting times are unavoidable.
I am sorry not to be able to give more positive information and still wish you good luck in your hunt for the debugger.
If the problem is resolved/answered, please mark this topic as answered by selecting Select as best. This will help other users find that answer faster.
/Peter
Peter BENSCH
/Peter
IMate.1
IMate.1Author
Thanks for taking the time to explain it.
