Paul1
Senior III
June 20, 2022
stlink-v3minie card edge connector
a) Any example part numbers for the stlink-v3minie card edge connector?
b) Is this card edge connector going to be standard for future ST-Links, or is the MIPI connector recommended?
Paul
JSui.1
July 9, 2022
I asked ST support (a) and they didn't give a recommendation. I later found it on page 10 of UM2910: reference connector part number is 009159010061911 from AVX. My team is still evaluating whether to adopt this connector because the MINIE is out of stock everywhere.
S.Ma
Principal
July 10, 2022
It is a kyocera board to board AVX10 connector which seems sold at distri like RS. 2mm pitch. A different compromise with tag connect.
Nikita91
Lead II
July 10, 2022
It looks like it's not a connector but an adapter. To use it you must have the same fingers on your PCB.
Open Ended Card Edge 00-9159_66716 Tantalum (mouser.fr)
Paul1
Paul1Author
Senior III
July 11, 2022
I like the look of this "double socket card edge adapter",
but the fact it isn't available in small quantity suggests to me this was designed in for a specific big customer's production.
Guess it is still MIPI connector + ribbon cable for us.
Paul
Nikita91
Lead II
July 11, 2022
Paul1
Paul1Author
Senior III
July 12, 2022
Nikita91,
Thank you, I see them, ordering now!
Farnell == Newark in Canada
Paul
April 24, 2024
Hi! I need Board to Board connector for stlink V3 minie soldered to PCB. Somebody knows something like that?
