Lukasz Przenioslo
STLINK-V3 not recognized
Hello there,
I have just obtained the STLINK-V3 device:
I have installed the STM32Cube Programmer (v 1.3.0) *** the drivers that comes along with it. The problem is that I cannot find the device:
There is no drivers missing, the device manager is "clean". I am using windows 10 64 bit version. Also there is no COM port available in the device manager.
According to the TN1235, this is correct:
I would appreciate all help.
Lukasz Przenioslo
Any support here please? @Imen DAHMEN​  ?
December 13, 2018
Ok, but what driver is it reportedly using here? That would be the most helpful screen shot.
Will try a V3 in a Win10 box later but honestly, it doesn't look to me as if you have the right drivers loaded/functional.
Get it to refresh or find the most current drivers on your box, check the Win10 settings for allowing that to occur.
Lukasz Przenioslo
Hi Clive,
This is an interesting situation. Will move further on my own then, trying to reinstall the drivers. Thank you.
S.Ma
Principal
July 25, 2022
If using a corporate pc, it security may prohibit usb memory storage class. Mbed boards or rpi pico wouldn't work as well if thus is the case. I think STLink has 2 driver versions, ine with mass storage disabled. Try it to compare. As it is a composite device pc allows all ar none....
September 28, 2023
Sorry , but I didnt see comments how you resolved this topic : I have the same topic
September 28, 2023
Having the same issue 5 years on perhaps something where you lead with specific detail of your situation.
Like what drivers are actually loaded against the ST-LINK/V3, and what ST-LINK/V3 are we talking about.
Solution: Get the right drivers loaded, make sure Windows recognizes the device, that you have the right cable, not a charger / power-only one.
