Jun 24, 2026 9:04 AM UTC
STLINK-V3 drag and drop Files
Hello Team,
I want to store Binary files in STlink-V3 Or any other model , to flash the target on the field without host PC / Cube Programmer.
I came to know , this device model has Bianary / hex file drag and drop feater , would it helpful in my scenario ?
If not , Suggets any other option.
Andrew Neil
Andrew NeilBest answer
Jun 24, 2026 9:22 AM UTC
No, the STLinks don’t store the bin/hex file locally - it’s just a “virtual” drive that appears on the Host.
However, “soon” you should be able to use a Raspberry Pi:
Otherwise, you would have to create something that could store the entire image, and then flash it to the target via either SWD or a bootloader - there have been many threads on doing this …
PS:
See also:
https://www.segger.com/production/single-unit-programming/
via: https://www.st.com/en/partner-products-and-services/segger-single-unit-programming-solutions.html
https://www.kanda.com/blog/microcontrollers/what-is-a-standalone-programmer/
(I searched “standalone field microcontroller programmer”)
Andrew Neil
PS:
See also:
bsutharAuthor
Jun 29, 2026 3:28 AM UTC
Thanks ​@Andrew Neil ,
Segger and Elpronic are expensive solutions.
Looks attractive , unforntunately , not released yet.
