arun singh
Nov 29, 2017 11:27 AM UTC
Stlink error
Posted on November 29, 2017 at 12:27
I have nucleof401re, everything was working fine for past 3 months but suddenly today Keil started giving error in connection. When I checked the storage, there was a text file named FAIL and it showed that interface firmware failed to reset the mcu. I tried google, upgraded the software but nothing seems to work.
Jumpers are connected as they were since the beginning.
Any help will be appreciated.
#stm32 #stlink-error #nucleo
arun singh
arun singhBest answer
Nov 29, 2017 6:02 PM UTC
Posted on November 29, 2017 at 18:02
Tried it but even STlink utility is unable to connect to it. I am getting error 'no stlink detected'.
Nov 29, 2017 3:44 PM UTC
Posted on November 29, 2017 at 16:44
Likely errant code reconfiguring debug pins or sleeping the processor. Change to 'connect under reset', or jumper BOOT0 High to prevent the code from running while you replace it.
arun singh
arun singhAuthorBest answer
