STEVAL-STWINKT1B - Can't recognize USB conection
Hi, I tried to connect my board to my computer trought USB but I can't recognize the board, it doesn't appear, I can't use the Programmer either. I downloaded different drivers, I used different cables but it doesn't work. What can I do? The BLE connection worked, I could get some data from a SD Card, but I want to use in a continuous measure.
Bruno1985Best answer
Thanks, it was a hardware problem (my USB connection was broken). IT is
fixed now.
Mike_ST
What board ?
Please, give more info please, if you want to increase your chances to get an answer.
This can be pictures of your setup, schematic, screenshots, driver version, etc...
Bruno1985AuthorBest answer
fixed now.
