Jul 25, 2025 6:39 AM UTC
STDES-2KW5CH48V Firmware
Hi All,
We are building a charger based on STDES-2KW5CH48V. On ST .hex file is available as firmware.
Is source code also available ?
Thanks in advance.
Regards,
Vimal
Peter BENSCH
Peter BENSCHBest answer
Aug 7, 2025 2:07 PM UTC
Welcome @vimalsingh126, to the community!
For security reasons, no source code is made available for such high-power applications. Also, only the design documentation is available from STDES, it is not offered for sale.
You are welcome to get in touch with your local distributor or sales contact who will help you realise your project if the quantity is large enough.
Hope that helps?
/Peter
Peter BENSCH
Hope that helps?
/Peter
