VVerm.0
St utility problem - cant connect to device
I have been trying to connect to stm32f30f4p6 using SWD but it shows cant connect to the device.
But when i connect other MCU it is able to connect to it .
Also, stm32f030 connects to the utility in another laptop.
Uwe Bonnes
Chief
January 4, 2019
Tripple check your wiring. Try to connect under reset!
S.Ma
Principal
January 4, 2019
Check the electrical: MCU supply voltage, SWDIO and SWDCLK signals and ground, reset pin voltage level, boot pin level.
January 4, 2019
For external ST-LINK the target voltage needs to be applied to pins 1/2
Is the non-working one a DELL? Through a hub or expansion dock?
Different policies or AV software? Remote Diagnostic tools?
Different drivers? Upper or LowerFilters on driver stack?
