Nov 11, 2025 2:25 AM UTC
ST Production-Grade Boards
Hi ST,
I'm looking for STM32 boards that are permitted for end-product usage. In particular, I find Nucleo wonderful but my understanding is they are not to be distributed in the product. Does ST offer any comparable SBCs to Nucleo that can be essentially be mounted on a host board without having to do a custom PCB just for the MCU? If not, to what extent can Nucleo/Discovery boards be used, f.e. development/evaluation only, test/cert, etc?
Historically I have seen assortments of off-the-shelf SBCs being used even in industrial/medical equipment which struck me as very practical and I haven't come across anything from ST for this, so maybe I am looking in the wrong place. Open to suggestions and guidance.
Thank you!
Peter BENSCH
Peter BENSCHBest answer
Nov 11, 2025 9:13 AM UTC
Like all boards from STMicroelectronics, NUCLEO boards are purely evaluation tools. According to the Terms of Use, they may not be used for end applications (see RESTRICTIONS AND WARNINGS and following text).
There are definitely manufacturers of boards that contain STM32 and possibly supporting devices such as crystals and capacitors. You should be able to find distribution channels using your preferred search engine.
Hope that helps?
/Peter
Peter BENSCH
Hope that helps?
/Peter
Andrew Neil
Nov 11, 2025 11:09 AM UTC
@JS5 wrote:
can be essentially be mounted on a host board without having to do a custom PCB just for the MCU?!
Why would you do a custom PCB just for the MCU?
Surely, you'd incorporate the MCU into the "host" board design?
waclawek.jan
Nov 11, 2025 12:51 PM UTC
I faintly recall that ST used to have some "partners" program, promoting producers of hardware/software and their designs registered at ST. I did not follow that so don't know what happened to it, but maybe searching on ST's website would reveal at least remainders of this program.
Peter BENSCH
Nov 11, 2025 3:43 PM UTC
Correct, the partner program can be found here.
