CEmrk.1
August 22, 2022
ST-Link works on one computer but not the other, why
I use Jtag with ST-Link on my computer and tries to erase chip on my PCB. However, it says "read out protect enabled". Now, the thing is, this wasn't enabled before I pressed on "erase chip" within ST-Link, but once I pressed it, it activated it. If I take out my device and run STlink again (without pressing on erase chip), it is set to disabled/level 0 again.
Now, if I try this at my friends computer with the same Jtag, it works without problem to erase my device. So the problem must be within my computer I assume? The question is, what can make this occur on ones computer? So that I can erase my device again.
Same versions of ST-Link is used.
August 22, 2022
Drivers, cables, docks or hubs?​
Semer CHERNI
Hello @CEmrk.1​
Maybe the issue is with the STLink driver try to reinstall it.
Also I advise you to try using the STM32CubeProgrammer.
Kind Regards,
Semer.
Pavel A.
August 23, 2022
Try a powered USB 2.0 hub (not USB 3.x)
