JCarr.9
ST LINK/V2 programmer support the Micro SMT32L475RCT7? This is the error when a try programming using command line: Cannot connect to the MCU device! Is there a patch to support SMT32L4? BR Juan
KnarfB
KnarfBBest answer
You may upgrade the STLINK firmware in STM32CubeProgrammer or STM32CubeIDE (under Help).
Otherwise, check your wiring.
hth
KnarfB
KnarfB
KnarfBBest answer
hth
KnarfB
JCarr.9
JCarr.9Author
Thank you so much KnarfB! , the issue was resolved with the new firmware, I apreciate your time and your fast response!
BR
Juan
