Senior
November 20, 2024
ST-Link Mini Connections
The STLink Mini data sheet has a pin labeled "T_NRST" I am wondering if this needs to be connected to the "DEBUG_JTRST" or the "NRST" pin of the microcontroller.
STTwo-32
STTwo-32Best answer
The ST LINK V3 does not support the DEBUG_JTRST signal. So, you have to do a JTAG Debug without it.
Best Regards.
STTwo-32
STTwo-32
Hello @EthanMankins
The T_* prefix stands for target. It should be connected to the NRST pin of the MCU you're programming.
Best Regards.
STTwo-32
Senior
November 20, 2024
@STTwo-32, Thank you, that begs the question now, where should the DEBUG_JTRST be connected?
STTwo-32
STTwo-32Best answer
Best Regards.
STTwo-32
