ST-LINK Cannot Detect Target – NUCLEO-F072RB – “Unable to get core ID” / “No STM32 target found”
- 3 replies
- 505 views
I am facing an issue while connecting to my board using STM32CubeProgrammer and ST-LINK. I would appreciate any help.
Board: NUCLEO-F072RB
Programmer: ST-LINK (Onboard)
Software: STM32CubeProgrammer
Connection: SWD
ST-LINK Firmware: V2J46M31
Issue Description:
STM32CubeProgrammer is unable to detect the target MCU. It shows errors like:
ST-LINK error (DEV_CONNECT_ERR)
Observed Details:
Target voltage showing around 0.29V
Connection mode tried: Normal (SWD)
Reset mode: Software reset
Speed: Reliable
Frequency: 4000 kHz
Log Messages (Important Parts):
Error: Unable to get core ID
Error: No STM32 target found!
Error: Problem occurred while trying to connect
What I Already Checked:
USB cable and port
Reinstalled STM32CubeProgrammer
ST-LINK firmware upgrade option checked
Tried reconnecting multiple times
Questions:
Is the low target voltage (0.29V) the reason ST-LINK cannot detect the MCU?
Could this be a power supply or hardware issue on the board?
Should I try different reset modes (Hardware reset / Connect under reset)?
Any recommended debugging steps for this case?
Thanks in advance for your support.
