Rotate the LCD TFT display by 90 degrees clockwise
I am using STM32F769I - Discovery board. I want to roate the display by 90 degrees clockwise.
Regards,
Nitesh
Hello @nitgbhat,
You can set the display orientation and make 90 degrees rotation within TouchGFX Designer (via Config tab > Display option) to Landscape or Portrait mode. You can also use STM32CubeMX by setting the display to 480*800.
