Vtrai
Mar 6, 2020 9:12 AM UTC
resistor details
my question is in STM32F407VGT6 , LPQF100, resistor R26,R27, R28 is N/A and 0..what does it mean exactly i.e.,one resistor R26 N/A is connected to VDD and another resistor R27,R28 is connected to VSS(99pin)..and second question is does VSS has a supply from VDD?..and what is N/A and what is '0' and what is the is use of those resistors?.. please help me to sort out this issue...
Mar 6, 2020 9:21 AM UTC
Sorry what BOARD or document are you looking at?
Some F4 and F7 parts within family have slightly different pin configuration so resistor fitted or not fitted​ may support broader range of parts, ie 407, 411, 427, 466 etc
Vtrai
VtraiAuthor
Mar 6, 2020 9:33 AM UTC
stm32f4discovery board
Ozone
Principal
Mar 6, 2020 9:25 AM UTC
The STM32F407VGT6 has no R27 and R28.
I guess you mean the Discovery board.
The term "N/A" usually means "not applicable", i.e. the component is not placed on the PCB.
It wouldn't make much sense to connect a VSS pin of the MCU to VDD via a resistor, except for creating additional current consumption.
Vtrai
VtraiAuthor
Mar 6, 2020 9:34 AM UTC
then what is the need of connecting those resistors in stm32f4 discovery board..and does VSS has a power supply now..which is usually connected to R27,R28
waclawek.jan
Mar 6, 2020 10:54 AM UTC
VSS means ground.
Pin 99 of STM32F407VG used to have a different meaning in the very distant past, see PDR_ON pin not available on LQFP100 package for revision Z devices erratum.
