Regarding ST-Link access on evaluation board STM32F769I-EVAL
Please let me know if normal USB cable can be used to connect to STM32F769I-EVAL board, load and debug the code or do we need to connect any other cable only for debugging purpose. Please reply with details.
Thanks,
mƎALLEm
mƎALLEmBest answer
All you need is a Micro USB/USB Type A cable.
Please be sure it's a data cable not just to power devices.
Connect it to this USB connector on the board:
STTwo-32
Hello @rdevisetti
You have to use a data cable not just for example a phone USB cable or other type of cables to make sure everything works fine.
Best Regards.
STTwo-32
mƎALLEm
mƎALLEmBest answer
