carlosdelfino
Senior
Jul 1, 2025 2:35 PM UTC
possible to use AEK-LCD-DT028V1 LCD + X-NUCLEO-53L8A1 sensor with Nucleo-F401RE?
I'm working on a second project using AI and I came across the ToF sensor that can be used to detect hand gestures. It is possible to use the AEK-LCD-DT028V1 LCD together with the Nucleo-F401RE board and the X-NUCLEO-53L8A1 sensor.
Andrew Neil
Jul 1, 2025 3:06 PM UTC
What does the display datasheet tell you ?
The Product Page says that it's an SPI display - so any microcontroller could drive that.
carlosdelfino
Senior
Jul 1, 2025 3:15 PM UTC
The issue is not the display itself, but the use of the board together.
Thank you for your interest in helping.
Buy me a coffeeMy Portal about Analog ElectronicsMy Youtube Channel where I share my learning about Analog Electronic
carlosdelfino
Senior
Jul 1, 2025 3:17 PM UTC
I just remembered that I will have to use Bluetooth, so I wonder if there will be a possibility of using the stm32wb board
Andrew Neil
Jul 1, 2025 4:03 PM UTC
Sure, the stm32wb can do I2C and SPI.
