Dec 2, 2024 6:22 AM UTC
NUCLEO-H753ZI voltage output
Can I output an adjustable voltage ranging from -10V to 10V using the h753zi development board?
I found something like a "PWM to 0-5V/10V DAC Module."
Would I need to use such an external module or build an additional circuit externally to achieve this?
I would appreciate your advice and look forward to your response.
Thank you!
Peter BENSCH
Peter BENSCHBest answer
Dec 2, 2024 7:38 AM UTC
As the entire NUCLEO board operates with a positive voltage, a negative output voltage can only be achieved with external circuitry, which in turn also requires a negative supply voltage.
So yes, for ±10V you would have to connect a level shifter, e.g. using opamps.
Hope that helps?
/Peter
Peter BENSCH
Hope that helps?
/Peter
