Oct 17, 2025 7:13 AM UTC
Nucleo h753zi, pc9 pc8 morpho header
is there any way to use the pads pc8 and oc9 on the morpho header of tve nucleo h753zi? They are lebeled but dont receive signal. I see the signals on the according pins of the zio header.
right now I am thinking of drilling the morpho pads away and connecting through the hole patched from the zio header. I was hoping for a better way
thanks for helping
AScha.3
AScha.3Best answer
Oct 17, 2025 7:34 AM UTC
so, from : https://www.st.com/resource/en/schematic_pack/mb1364-h753zi-c01_schematic.pdf
...solder sb14 + 15. Then ...ok ?
AScha.3
AScha.3Best answer
yentzeeAuthor
Oct 17, 2025 7:58 AM UTC
Perfect, that solved the problem. Thanks a lot :)
