FBelt.1
MXCHIP WiFi protocol on B-U585-IOT02A
I am working with B-U585-IOT02A.
In all example project using NetXDuo stack tcp/ip (web server, Azure Iot Hub, ecc. ecc.) the communication with wifi mxchip is performed by SPI using IPC -HCI command protocol.
I haven't found documentation about command accepted from SPI by MXCHIP module.
I need to know what command are received by mxchip wifi, because they are not standard AT command, and I need to develope a project with STM32U585 with a different chip wifi.
Several other wifi chip accept only AT command, and I need to analyze the difference and the structure of sample projects.
Best Regards
Fabrizio Beltrandi
Andrew Neil
@FBelt.1 wrote:
using NetXDuo stack tcp/ip ... I need to develope a project ...  with a different chip wifi.
Perhaps it would be easier to just find a WiFi module supported by NetXDuo ?
FBelt.1
FBelt.1Author
Thank you Andrew,
I know that wifi modules supported by NetXDuo need to work in data mode bypassing on chip tcp/ip stack.
Do you know other behavioures needed?
Best Regards
Fabrizio
Andrew Neil
Andrew Neil
There's a company contact given here:
https://www.st.com/content/st_com/en/partner/partner-program/partnerpage/MXCHIP.html
See also: https://www.mxchip.com/en and https://www.mxchip.com/en/about-us/contact
