Microcontroller dead
Morning everybody
The microcontroller on my nucleo board NUCLEO-H755ZI-Q is dead after i have used 5V external power to supply it. I don't understand why
Uwe Bonnes
Chief
June 19, 2024
Read the data sheet and understand "Maximum ratings" Applying 5 Volt to an FT pin when the chip is unpowered will kill the chip as applying 5 Volt to a TT pin when powered.
FistelAuthor
Please, what mean "FT pin" and  "TT pin" ?
Uwe Bonnes
Chief
June 19, 2024
Have a look at the datasheet table "Legend/abbreviations used in the pinout table"
Senior III
June 20, 2024
On which pin or connector did you apply 5v? Try to connect to usb, and see if its getting detected by cube programmer.
Uwe Bonnes
Chief
June 20, 2024
If the MCU heats up fast, it is broken. Been there, done that 8-)
FistelAuthor
The MCU doesn't heat
