Dec 21, 2024 6:10 AM UTC
LED toggling
I am using NUCLEO-U575ZI-Q eval board. I am trying to blink RGB LEDs. But RED LED which is connected GPIOG pin 2 is not toggling.
Tesla DeLoreanBest answer
Dec 21, 2024 6:16 AM UTC
Have you used commands to enable the VDDIO2 power to the GPIOG bank?
No code shown
HAL_PWREx_EnableVddIO2();
#define LED3_PIN GPIO_PIN_2
#define LED3_GPIO_PORT GPIOG
#define LED3_GPIO_CLK_ENABLE() __HAL_RCC_GPIOG_CLK_ENABLE()
#define LED3_GPIO_CLK_DISABLE() __HAL_RCC_GPIOG_CLK_DISABLE()
No code shown
Jan 28, 2025 2:48 PM UTC
I had the same issue. Adding a call to HAL_PWREx_EnableVddIO2() fixed it. Thank you.
Andrew Neil
Dec 21, 2024 10:43 AM UTC
Welcome to the forum.
More details required - see: How to write your question to maximize your chances to find a solution
Have you checked (board User Manual & Schematics) that there's nothing else on the board occupying those pins?
