RPush
KiCAD library for STM32F769I Discovery boards needed
KiCAD library for STM32F769I Discovery boards needed. I need a KiCAD library to use with the STM32F769I discovery boards so the discovery board can essentially be a component in my project. The plan is to have a daughter board exactly the same size as the STM32F769I DISCO board so the two can plug together and fit inside of a case.
S.Ma
Principal
June 3, 2019
If KiCAD can import Altium file, there is a possible way out.
RPush
RPushAuthor
There is a conversion tool here: http://kicad-pcb.org/external-tools/altium2kicad/. Do you know where I can find the required Altium source files to use for input to do the conversion. I quick Google search didn't turn up any.
June 3, 2019
It would help to key in the right part number. I think Gerbers are available.
There types of questions are best directed at the FAE supporting your account. Check with your local sales/support office.
Although I will note ST doesn't approve of these boards being used in commercial products.
