jhasa.1
is it possible to connect SRF05 module (ultrasonic) to stm32f030k6t6 and work with 3.3V?
MM..1
Yes you need connect to 5V tolerant pins
jhasa.1
jhasa.1Author
Can I connect Vcc to 3.3V and work with it?
MM..1
This info you need ask SRF05 author...
Andrew Neil
You could've started by summarising the suggestions you've had already:
https://www.avrfreaks.net/forum/working-srf05-33v
