HLee.9
Is it normal for Code State: halted in LiveUpdate of ST-LINK Utility ?
The MCU that I used well does not work.
All newly loaded MCUs are the same.
The same is true after programming a hex file to the MCU using the ST-LINK Utility.
The most commonly used tools are TrueStudio and STM32CubeMX.
Halt occurs after MCU is loaded and does not work.
Could you tell me how to find the problem?
