DGold.11
In-circuit debugging for STM32H743 at 1.8V using STLINK-V3SET
I see the manual for STLINK-V3SET refers to B-STLINK-VOLT as an orderable part that does the level shifting from 1.8V to 3.3V. However, I cannot find this part available at any distributor (Mouser, DigiKey, etc.). Am I missing something? Can someone help explain how I can do debugging on this chip when operating at 1.8V? I've never had any issues in past when using chips at 3.3V.
Uwe Bonnes
Chief
May 15, 2020
You need level translating buffers. For SWD things get complicated as SWDIO is bidirectional. B-STLINK-VOLT may be mentioned by ST, but it seems not available. Look how other debuggers do the translation, e.g. the Bl*ckm*g*c debug probe.
Linas L
Senior
May 16, 2020
Hi.
Look at NUCLEO-L433RC-P development board. It has switch for 1.8V and 3.3V operation, and debugger is SWD with somekind bidir level shifter .
https://www.st.com/en/evaluation-tools/nucleo-l433rc-p.html
DGold.11
DGold.11Author
This is helpful. Thank you!
