Identifying Debugger for STM32H503KB MCU
Greetings,
We are planning on using STM32H503KB MCU at 250MHz for our application. We have tested our code on NUCLEO board MB1814B which had an internal debugger IC STLINK-V3EC. For development what is the debugger tool that we should procure for easy flashing and debugging. Based on our research, we have found ST-LINK/V2 to be optimal for our solution.
Kindly provide us with your thoughts.
Thanks and regards,
Ravichandran. C
Yes ST-LINK/V2 will do.
But personally, I prefer working with SEGGER's J-Link which have better performances but is also more expensive.
S MARIE
Hi Marie,
Thank you for your input.
Ravichandran
Andrew Neil
Hi Andrew,
I have looked at the products you have mentioned and have decided to go with ST-Link V2 since we only need SWD pins and ST-Link V3 have lot more functions and V2 is a bit cheaper compared to V3-Set.
Thanks and Regards,
Ravichandran
