June 25, 2024
I need Hardware design guidelines for design the customized board for my projects using STM32 chip
I need step by step guidelines to make my custom board for my projects
Different chips need different capacitors crystal oscillators and some defile connections
i need to know that can you please guide me for that
If you give me the full tutorial, that means it's very useful to me
STTwo-32
Hello @KARTHI1
What i suggest you is to refer to the Application Note called "Getting started with STM32xxxxxx MCU hardware development" for example here is the one for the STM32F4. You will find a version of this Application Note for all our MCUs.
Best Regards.
STTwo-32
Andrew Neil
Open the Product Page for whatever particular STM32 chip you're using, and go to the 'Documentation' Tab.
There you will find:
  • the Datasheet - which gives you important electrical specifications, and some circuit tips
  • the "Getting started with STM32xxxxxx MCU hardware development" Application Note already mentioned by @STTwo-32
  • Many other Application Notes covering more specific details; eg, oscillator design
Also, on the 'Tools & Software' Tab, you will find links to ST's evaluation/development boards - you can look at the schematics & PCB designs of those for inspiration ...
