RNaik.4
I'm using STLINK-V3SET debugger. IDE is CooCox. MCU is STM32F405ZGT6. As I try to launch a debug session, the stages "flash erase, program and verify" are completed and the debug session aborts instead of allowing to run the code. Why?
August 31, 2022
Suggest you discuss with Coocox support​
Perhaps the download app has different return or completion codes..​
RNaik.4
RNaik.4Author
Thanks for your inputs.
I could solve this by using a different toolchain.
