Aug 11, 2025 9:16 AM UTC
I cant connect to my EVALKITST8500-1 using Smartgrid LabTool V4.4.
The power cable and the USB cable for kit interface are connected properly.
When I connect the interface cable as per the the quick start guide, the LabTool does not recognize any port. If I go to settings - port: I can find no port to chooseIf I go to settings - COM port - Scan port: Again, nothing happens.In my windows device manager, I can see two new devices which don't have the appropriate driver, there are named: Enhanced COM port, and standard COM port. #evalkitst8500-1 #smartgrid-labtool
MatKozBest answer
Aug 12, 2025 7:21 AM UTC
I have solved the issue. It turns out that drivers for CP2102 USB to Serial bridge were needed on my side.
Aug 12, 2025 7:17 AM UTC
Hello @MatKoz,
This post has been escalated to the ST Online Support Team for additional assistance. We'll contact you directly.
Best regards,
Maxime
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
MatKozAuthorBest answer
