How to test if a MCU is broken?
Hi all!
I have developed a PCB with a stm32f4 MCU.
The MCU can be programmed through SWD and works well.
However, the current consumption of the whole PCB is high (~190 mA at 3.3 V). When I erase the chip, the current consumption becomes 120 mA.
Could you recommend what could I do to understand, if the high current leakage is due to the broken MCU or due to problems in other PCB units?
Thank you in advance
