Aqsa
How to measure STM32F767 zi only microcontroller part power consumption using X-NUCLEO-LPM01A
Hello, i want to measure the power consumption of STM32F767zi only MCU Part using X-NUCLEO-LPM01A. The step of manual says to "open the SB110" by default SB110 is ON what are the ways to make it open ? can we do it through wires or some jumpers?
FBLBest answer
Hello @Aqsa​,
If the hardware setup is preconfigured by default, you can just ensure as referenced in the user manual. Try this tutorial for further explanation.
STM32Cube tools in practice - STM32CubeMonitorPower in practice - YouTube
You need to port it to your board using F767. Are you using Nucleo-F767ZI or custom board?
FBLBest answer
Hello @Aqsa​,
Aqsa
AqsaAuthor
yes i am using this board ..thank you
