Oct 29, 2025 3:30 PM UTC
How to debug the Seeed Studio AI Assistant board using a STLink/V2 debugger
We have bought the new AI Assistant board from Seeed Studio and we need some help on how we can connect an external debugger.
We have two STLink/V2 debuggers, the plain and the ISOL version. However with the cables that they have we cannot connect any of them to the 8-pin debug port of the Seeed board.
We assume that the necessary pins are on the STM32 connector, but which are they? Additionally the picture of the STLink/V2 debugger in:
https://wiki.seeedstudio.com/ai_assistant_getting_started/#additional-documentation-of-the-application
does not correspond to the debugger we have. Is that a different board from the one we have?
https://www.st.com/en/development-tools/st-link-v2.html#overview
Thanks in advance
mtvBest answer
Oct 31, 2025 3:14 PM UTC
First of all thanks for the reply. It is good to know the support options of Seeed Studio.
I wrote here because in the end of
https://wiki.seeedstudio.com/ai_assistant_getting_started/#resources
it clearly says that the product is supported by STMicroelectronics.
Also in the photo with the pinout next to ST-Link V3 it also has an image that says ST-Link V2.
However I found the solution searching the STMicroelectronics site. I found the technical note TN1235 "Overview of ST-LINK derivatives" and I understood that the photo in the Seeed site actually corresponds to the ST-Link V2-1 version that includes the Uart pins. The plain ST-Link V2 debuggers do not have the Uart pins.
So finally with a Nucleo board as in the photo I managed to connect with the board.
Thanks again
Andrew Neil
Oct 31, 2025 11:17 AM UTC
As it's a Seeed Studio board, you should be going to Seeed Studio for support:
https://aftersale.seeedstudio.com/home
https://forum.seeedstudio.com/
https://discord.com/invite/QqMgVwHT3X
Particularly as it's a new product, you need to feeding back to them on needed improvements!
That really is a question for Seeed Studio!
But the schematics are on the page you linked:
As it says in the picture, that's an ST-Link V3:
https://www.st.com/en/development-tools/stlink-v3set.html
mtvAuthorBest answer
Thanks again
