NGUYEN-VAN NHI
Hi, i am facing a very annoying problem, i am using STM32H755ZI-Q 144 NUCLEO KIT, when i connect it get STLink, but not receiving chip, can anyone help me, thanks thank you very much
July 26, 2022
What does the error message actually say? Target Not Found?
Did you get the LDO/SMPS settings wrong?
Try power cycling the board with BOOT0 HIGH, see if it will connect, and then erase the broken user code.​
NGUYEN-VAN NHI
Yes, the real error is "Target not found". I am trying to try the way you suggested. Thank you.
Andrew Neil
Please don't put the entire post in the Title - see:
https://community.st.com/s/article/How-to-Post
Limit the title to ~ 70 characters.
#KeepTitleShort
NGUYEN-VAN NHI
Oh my bad mistake, thanks for the reminder.
