F407 Discovery - MEMS microphone -DSP-DAC-Headphone (DMA and PDM to PCM, double buffer, half buffer)
I have been looking for software that can take as an input, the PDM output from the MEMS microphone, and convert it to PCM.
I then want to implement a double buffer using DMA, to reduce CPU load and output the audio data to the DAC on this PCB.
Once I have this running I want to experiment with DSP, filters, delay lines etc...
If no software is available, does anyone know if a process is defined, with comments on why each element of the process is as it is for learning purposes?
Thanks in advance
BarryWhit
Lead
July 15, 2024
"- If someone's post helped resolve your issue, please thank them by clicking ""Accept as Solution"".- Please post an update with details once you've solved your issue. Your experience may help others."
Thanks for that, but Im looking for something more basic for a beginner. Some sample code with process for learning purposes.
I'll certainly take a look at the links and do some head sratching....
