diode
HelIo,
I connected the anode from a diode to the operating voltage and the cathode to a pinx. I need ground to make the diode glow.  How can this be implemented?
    January 5, 2024
    Well you'd need a resistor to limit current through the LED, as if you simply gate it to ground you'll get whatever the transistor will permit.
    PINX ----[ R ]----|/|-- VCC
     LED|\|
    Configure GPIO as PP or OD OUTPUT, LOW to illuminate
    SaxAuthor
    I already have a resistor in the hardware. Unfortunately, these settings don't work.
    January 5, 2024
    Perhaps draw what you've built
