RAltm
Senior
December 3, 2020
Detecting ST-Link V2-1 virtual COM port with C#?
  • December 3, 2020
  • 761 views
I want to connect to the VCP of a Nucleoboard by a C# application. I don't want to iterate through all available COM ports on the system, so I'm searching a way to detect if one or more Nucleoboards are connected and connect to the corresponding VCPs. Has anyone already tried that and can give me some hints?
Uwe Bonnes
Chief
December 3, 2020
Well, you have to iterate through the registry. In bl*ckm*g*c does that to find the gdb port. BMP is on github https://github.com/blacksphere/ The iteration is in src/platforms/pc/serial_win.c
December 3, 2020
+1
Both COM port and USB assocativity can be fished out of the registry​ trees/nodes
