Anton Martinsen
Default HSE set to 25 MHz for NUCLEO-F722ZE
Is it intented for STM32CubeMX drivers for NUCLEO-F722ZE to have 25MHz as HSE input by default? The hardware I bought from ST had an 8MHz oscillator as input for HSE, not 25 MHz.
Amel NASRI
Hi @Anton Martinsen​ ,
This is reported to our STM32CubeMX development team who will take care to bring required corrections.
Thanks,
-Amel
September 29, 2020
Seen the stm32xxxx_hal_conf.h​ contain the wrong HSE_VALUE on occasion as examples moved from EVAL or DISCO series boards with alternate clocking for Ethernet, etc.
As a general rule I tend to print CPU and bus speeds to a debug console so I can quickly check they are as expected, helps when dealing with dozens of boards.​
Amel NASRI
Hi @Community member​ ,
Which example please? What I noted is the difference between stm32f7xx_hal_conf.h and system_stm32f7xx.c regarding HSE_VALUE for same project. This has to be highlighted as well.
-Amel
September 29, 2020
It was more of a historic observation, a quick grep yielded this non-comprehensive list
STM32Cube_FW_F7_V1.16.0\Projects\STM32F767ZI-Nucleo\Examples\FLASH\FLASH_SwapBank\Inc\stm32f7xx_hal_conf.h
STM32Cube_FW_F7_V1.16.0\Projects\STM32F767ZI-Nucleo\Examples\SPI\SPI_FullDuplex_AdvComIT\Inc\stm32f7xx_hal_conf.h
STM32Cube_FW_F7_V1.16.0\Projects\STM32F767ZI-Nucleo\Examples\SPI\SPI_FullDuplex_AdvComPolling\Inc\stm32f7xx_hal_conf.h
Nesrine.JLASSI
October 9, 2020
Hello @Anton Martinsen​
Thanks for the feedback, issue reported to the tool development team that will plan the correction.
Best regards,
Nesrine
