Debugger Stuck at HAL_GetTick() Function
- 7 replies
- 7567 views
Hello STM32 community,
I'm encountering an issue with my STM32L562VET controller where the debugger gets stuck at the `HAL_GetTick()` function. When debugging, the program seems to halt at this point, making it difficult to proceed with the debugging process effectively.
Additionally, I've noticed that when using EXTI1_IRQn or EXTI8_IRQn interrupts, the debugger fails to display the location of the current line being executed. This lack of visibility into the code execution flow hampers my debugging efforts even further.
It's worth mentioning that I'm using TZEN = 0 configuration. I've tried troubleshooting this problem by checking my interrupt configurations and ensuring that all necessary initialization steps are correctly implemented. However, I haven't been able to resolve the issue.
Has anyone else in the community encountered similar problems with debugging on STM32L562VET controllers with TZEN = 0 configuration? If so, I would greatly appreciate any insights, suggestions, or solutions you might have to offer.
Thank you in advance for your assistance.
Best regards,
Giridhara Datta G
