Jun 20, 2025 11:23 AM UTC
Data is not received from the MP34DT06J Mic
I am using the X-NUCLEO-CCA02M2 expansion board with the Nucleo-H755ZI-Q, and I’ve confirmed that the MP34DT06J microphone is receiving the correct clock signal. Proper VDD and ground are also supplied to the mic. However, when I probe the DOUT line with an oscilloscope, there is no data output observed. Is there something I might be overlooking?
Jun 24, 2025 11:36 AM UTC
Hello @Aravind0601,
This post has been escalated to the ST Online Support Team for additional assistance.  We'll contact you directly.
Best regards,
Maxime
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
