deep_rune
connecting an XTAL with an STM32L412
I want to connect an (HSE) crystal with an STM32L412 - I see from the cubeIDE ports that PA0 is the CK_IN, but I've always used xtals with two ends - where does the other end of the xtal connect to? Ground?
September 15, 2020
Need to use an oscillator, like a TCXO, or existing clock source in your system
deep_rune
deep_runeAuthor
sorry i don't understand... i just want to use an external crystal to time my chip, how can i do this? do i need to use the RCC osc pins? Im not sure
September 15, 2020
You have to make the crystal oscillate externally, you could use a pair of inverters if you insist on doing it from scratch​
