Jun 11, 2025 4:29 AM UTC
Configuring CAN Drivers to the STM32L4R9I-EVAL board
As I tried to find CAN drivers for " STM32L4R9I-EVAL" but I didn't find any, And I tried configuring CAN example of Stm32L476G-Eval board but it is not working.
Anyone who worked on CAN (Protocol )configuring on STM32L4R9I-EVAL board please Guide me in this
mƎALLEm
mƎALLEmBest answer
Jun 11, 2025 8:33 AM UTC
Hello @sonic_solutions and welcome to the ST community,
Attached a preliminary configuration of CAN1 on STM32L4R9I-EVAL board: PB8 and PB9 are used for CAN communication.
But from hardware standpoint, you need to ensure:
JP12 & JP13: fitted.
JP14 fitted in position 1-2:
Remove R235 and R243:
You need to connect another CAN node to the board that has a 120ohm terminating resistor connected on it.
Hope that helps.
mƎALLEm
mƎALLEmBest answer
Hope that helps.
Jun 11, 2025 10:37 AM UTC
Thank you very much for the solution. However, I’m still unclear about the core point.
My main concern is that I need CAN files such that, when the code is flashed onto the STM32L4R9I-EVAL board, it should behave in the following way: upon receiving a CAN message, the board should either print a response or perform an action in response to that message.
Could you please help me with this
mƎALLEm
Jun 11, 2025 10:39 AM UTC
Please follow the new discussion in this post.
Thank you
mƎALLEm
Jun 11, 2025 10:19 AM UTC
The new question moved to this post.
