Build Ethernet function with Eval Kit NUCLEO-H723ZG
Dear Team,
I am trying build Ethernet function with Eval Kit NUCLEO-H723ZG with STM32H723ZG MCU.
However, Mostly is okay but i cannot ping to IP address set in Init.
Could you check and recommend.
Brgs,
Thinh
Hello @Chicharito
Did you check this FAQ How to create project for STM32H7 with Ethernet an... - STMicroelectronics Community
Since the issue is linked to init, it is likely due to MPU configuration.
Hi Belaid,
Thanks for suggestion.
Let us try again.
