Nov 28, 2020 8:48 AM UTC
Blupill development board STM32cube IDE & STM32 utility problem?
- 2 replies
- 1149 views
Hi ,
Recently i buy STM32F103c8 Bluepill development board. I use STM32CUBEIDE create LED project and download using STM32utility tool. After programming done it will be automatically disconnect.Next, If need connect in STM32utility means need reset while connection making.otherwise it will not be working..
By using coocox , i create sample Led Program and i download it through STM32Utility tool. Above problem is solved. always we connect and disconnect and program, program&verify . all is working fine..
Why Bin or Hex created fron STM32cubeIDE is getting this problem. Any solution to solve this problem. I attach video. Check it
