B-L4S5I-IOT01A Pin Failure
  • July 12, 2024
  • 1 reply
  • 750 views
Dear Team,
 I have Tried to flash B-L4S5I-IOT01A board I not able connect the board the I will verify U14 LDO supply
if JP5 -jumper is placed LDO input show 2.6v and Output 1.6V in multimeter
else JP5 - jumper is not placed LDO shows 5v and Output 3.3v in multimeter.
then Controller is more heat produced but if we are using U13 external power supply means working fine.
if any controller pin failure? how to figure out that?
Joe WILLIAMS
Hi M_Sukumar
This post has been escalated to the ST Online Support Team for additional assistance.  We'll contact you directly.
Kind Regards
Joe
STMicro Support
