Mar 1, 2024 8:11 PM UTC
Advantage of using a pin assigned to a core on multicore MCU
I new to multicore MCU progamming and i was wondering what is the advantage of using a pin assigned to a core instead of setting it free ???
Mar 3, 2024 1:08 PM UTC
Setting a pin to a core generally puts the initialization code in that core's code. If you want to use the pin, it generally needs to be initialized somewhere.
