WGorm.1
X-NUCLEO-NFC06A1 connections to raspberry pi
Can X-NUCLEO-NFC06A1 module be connected to a raspberry pi without ARPI600 raspberry pi to Arduino adapter? If not, which Arduino is recommended to run the module?
    Brian TIDAL
    Brian TIDALBest answer
    as far as I know, the ARPI600 acts as an interposer between raspberry connector and Arduino shields.
    If you do not have an ARPI600, you can use wires between the raspberry connector and the X-NUCLEO-NFC06A1.
    You can also run the NUCLEO-NFC06A1 on NUCLEO-L476RG with the stm32duino port (https://github.com/stm32duino/X-NUCLEO-NFC06A1) or with bare metal application (ST25 embedded NFC Lib)
    Rgds
    BT
    Brian TIDAL
    Rgds
    BT
