JSu.1
X-NUCLEO-NFC05A1 GUI Tools
Is any PC GUI tools with X-NUCLEO-NFC05A1 for function estimation easy?
X-NUCLEO-NFC05A1 can be adapter with NUCLEO-F401RE MCU board, but it has no PC GUI tools to work with NFC function estimation as 3911B-Discovery board.
I only saw the firmware driver available?
please kindly advice.
Thank you.
    Brian TIDAL
    Brian TIDALBest answer
    the structure folder is described in the User Manual UM2253. For NUCLEO-F401RE , the binaries for the applications are located in: STM32CubeExpansion_NFC5_V2.0.0\Projects\STM32F401RE-Nucleo\Applications\PollingTagDetect\Binary
    Rgds
    BT
    Brian TIDAL
    X-NUCLEO-NFC05A1 can be used with X-CUBE-NFC5 software expansion package. This package provides 2 turnkey sample applications: the first application detect tags and displays tag UID on the serial com port; the second application reads and display an NDEF message on the serial com port. On PC side, only a serial com terminal is needed to display the informations sent by the applications. No GUI is needed for those sample applications.
    X-NUCLEO-NFC05A1 can be used to easlily prototype an application by reusing the sample applications provided by ST.
    Feel free to provide more information about your use case and specific needs.
    Rgds
    BT
    JSu.1
    JSu.1Author
    Hello, Sir
    As you mention 2 turnkey samples application, where folder they located in X-CUBE-NFC5 firmware after uncompressed .zip?
    [cid:image001.png@01D5B728.CBDBC450]
    Thank you.
    Jerry
    Brian TIDAL
    Rgds
    BT
